Car judders when pulling away in first gear
It appears to be intermittent. I have replaced the spark plugs, coil pack, the leads and air filter. Car only judders when pulling away in first gear after I’ve been driving it for some time. Doesn’t do it when it’s cold from what I’ve gathered.
I have had clutch and flywheel looked at and no problems there. Engine mounts have also been checked and no problems there either. It feels more like a misfire to me. Really hope you can help it’s driving me nuts.
Re: Car judders when pulling away in first gear
It does sound like a problem with either the clutch or flywheel and while being annoying might not get my worse. If someone had a proper look at the clutch and flywheel I presume they took off the gearbox and it would have been a good idea to change the clutch at that time. It could also be oil from the crankshaft deal dripping into the clutch plate. If you are sure it is more like a misfire it could be a crack in the head gasket that is only obvious when the car is hot. Check the cooling level.
Hi there, many thanks for your response. I now have a delay when I depress the gas pedal. Takes about two seconds before the Rev counter moves when I fully depress the gas pedal. I’m going to assume now it’s the MAF. Can you guide me in the right direction as to where it is located? I think I’ve found it but just want to be certain. Many thanks in advance.
Hi, thank you for this.
Had a similar problem with the MAF on my wife's Suzuki SX4 many years ago: rough tickover & pick up when starting off.
I remember cleaning it with electrical contact cleaner with a good result.
Last edited by pittstop on Sat 18 Apr 2020 - 17:25; edited 1 time in total (Reason for editing : update)
» Car hesitates / splutters while pulling away
» Gear Change Light
» Clutch, changing gear problems
» MOT FAILED/PASSED
» Gear Change Light
» MOT FAILED/PASSED
