Roof problem
Page 2 of 2 Previous  1, 2
Roof problem - Page 2 Empty Re: Roof problem
Post by colin565 on Wed 11 May 2016 - 11:00
Did you get the fault code number per chance?
Post by knebby on Wed 11 May 2016 - 11:33
I couldn't imagine you with your top on permanently Barbs, glad its sorted!
I've never looked at the mechanism while the roof has been cycling so I've no idea what the photo is showing me. I'll take a look, find out where it is and see how much gunk I've got. Thanks for the heads up and info.
Post by Bullyboy on Wed 22 Jun 2016 - 20:13
Reading this thread is this common that gunk can cause problems ?  Thanks
Bullyboy
Bullyboy
Post by Barbs on Wed 22 Jun 2016 - 20:57
I don't think so I work in a very dirty environment and we are doing all we can at work to sort the dirt.
Post by Bullyboy on Wed 22 Jun 2016 - 21:54
Thanks just reading up on issues
Bullyboy
Bullyboy
Post by Bullyboy on Wed 22 Jun 2016 - 22:18
Also some posts mention a roof key ? Presume this should be in the glove box ? Thanks guys
Bullyboy
Bullyboy
Post by Barbs on Wed 22 Jun 2016 - 22:29
There is a roof key.Get the dealer to provide one and yes glove compartment. If the roof does fail you can't open the boot. But as I said mine was an unusual situation. I didn't even know how to remove the Renault badge at the back. The point of the Forum is the problems you may never encounter but a good reference point to start from if you do.
An owner for nearly 5 years and still over the moon with my Wind.
Post by Bullyboy on Thu 23 Jun 2016 - 18:18
Thanks barbs
Bullyboy
Bullyboy
Post by Barbs on Sat 23 Feb 2019 - 7:09
@renkev this might help.
Post by Bunyip on Sat 16 Mar 2019 - 8:40
Next time I have the roof open - 2 jobs a) spray copious amounts of silicone spray which I bought to lubricate electric windows to roof running gear and b) run some furniture polish which also contains silicone over the rubber mounts where the roof joins the body to prevent sticking.
Laughing
Bunyip
Bunyip
Post by BobbyA on Tue 19 Mar 2019 - 18:05
Just had a problem with my roof, after last week when car electrics died, I took off negative lead on battery for 10 mins which brought the electrics back.
Went to open the roof today and nothing !!
Removed fuse 26 and checked it, all good put it back in and hey presto !! Roof works.
This must have reset it
BobbyA
Post by Bunyip on Sat 23 Mar 2019 - 5:26
Well done Bobby lol!
Bunyip
Bunyip
Post by johntymac on Mon 1 Apr 2019 - 13:17
Help needed. Rear wiper has stopped working.
Hope you got it sorted afterall it is April the 1st Smile
johntymac
