Drivers window.
Drivers window.
Hi everyone,
I have encountered a problem with my driver's window. It refuses to open. I have had the "won't fully close" problem and know how to sort that now, but this seems to be something completely different?
I have looked in my user manual to find the fuse/s and can find no mention of the windows - unless I am blind.
Are there separate fuses for each side? (passenger side still working)
What number are they? (if two)
If not a fuse, what else should I look at?
The door is difficult to close without the window drop and I'm worried about breaking the glass if I don't sort it.
Cheers John.
Cheers John.
jmee54- Put the sunglasses on
Re: Drivers window.
Cut & paste; from handbook has emerged improperly but still tells the tale: Electric Windows are Fuse 23 so can't be the fuse unless both windows are out of action.
Fuses (2/3)
1 and 2 Windscreen wiper.
11 Direction indicator lights/ Diagnostic socket.
19 Location reserved for additional equipment.
3 Power-assisted steering.
12 Power supply/Instrument panel.
20 Front and rear fog lights.
4 Location reserved for additional equipment.
13 Dipped beam headlights.
21 Main beam headlights/ Horn.
14 Central door locking
5 Brake light/Speed limiter.
15 Side lights.
22 Location reserved for additional equipment.
6 Reversing lights/door mirror control/alarm siren.
16 Location reserved for additional equipment.
7 Air bag.
17 Heated rear screen/Heated door mirrors.
23 Electric windows.
24 Location reserved for additional equipment.
8 Passenger compartment electrical unit/transponder.
9 Injection/fuel pump.
18 Interior lighting/courtesy light/automatic climate control.
25 Dipped beam headlights/ rear fog light.
10 ABS/ASR/ESP
26 Sunroof.
Fuses (3/3)
27 Location reserved for additional equipment.
36 Location reserved for additional equipment.
43 Left-hand side light/number plate light.
28 Passenger compartment ventilation.
37 Heated door mirrors.
44 Location reserved for additional equipment.
29 Radio/Passenger compartment electrical unit.
38 Horn.
30 Accessories socket.
39 Rear fog lights.
45 Diode protection.
31 Location reserved for additional equipment.
40 Location reserved for additional equipment.
46 Location reserved for additional equipment.
32 Right-hand main beam headlight.
41 Heated seats.
47 Location reserved for additional equipment.
33 Left-hand main beam headlight.
42 Right-hand side light/ accessories socket/cruise control/speed limiter control/central door locking control/hazard warning lights control.
34 Right-hand dipped beam headlight.
35 Left-hand dipped beam headlight.
48 Radio
Fuses (2/3)
15 Side lights.
7 Air bag.
10 ABS/ASR/ESP
26 Sunroof.
Fuses (3/3)
38 Horn.
39 Rear fog lights.
41 Heated seats.
48 Radio
Re: Drivers window.
Thanks for that. One possibility deleted!
» Drivers window 2.
» Drivers window does not rise
» Removal of the window
» drivers window drops much when open door
» Window drop
» Window drop
