Window drop
Window drop Empty Window drop
Post by Davey1983 on Fri 18 Jan 2019 - 9:28
Hi, I would be grateful for any help or advice.
This morning I’ve unlocked the car, drivers window has dropped as usual when opening the door but has not retracted once the door is closed.
Opened the door again, but window just drops further. Window will close fully once the ignition is on and button used to close it.
Tried a few times but won’t close with the door.
Thanks in advance
David
Davey1983
Window drop Empty Re: Window drop
Post by johntymac on Fri 18 Jan 2019 - 14:16
HI DAVEY, ROLL DOWN WINDOW HOLD FOR 20 SECONDS THEN ROLL UP HOLD AGAIN REPEAT.
johntymac
Post by marelro on Wed 12 Jun 2019 - 20:52
Hi johntymac!
Your advice saved me time and money!
After a battery change I had the problem that the window at the driver side would no longer go totally up when I had the door closed.
I came to the forum, made a quick search, went out to my Wind and 2 minutes later returned to the waiting family with a very big smile!
marelro
marelro
