Knocking noise when on full lock
Andyk
scittney
Hello!
My wind has developed a knocking noise at low speed when the steering is on full lock. ie. doing a three point turn or parking. Anyone had the same or got any ideas?
thanks in advance.
thanks in advance.
scittney- Set the stereo
Re: Knocking noise when on full lock
scittney wrote:Hello!
thanks in advance.
It could be the Constant Velocity (C.V.) joint on one of the drive shafts. That would be my first check.
Andy
Yep that is a classic symptom of a worn CV joint. You may be able to identify which one it is by checking the rubber bellows that cover it just behind each front wheel mounting where the driveshaft bends. The one that's worn is likely to have a ripped or holed bellows which will allow crap in and lubricant out hence leading to the wear.
Timtnx- Put the sunglasses on
It could be a broken front spring, I had that on another car.
If it is, it is better to replace both at once.
Jim777- Took the roof down
Thanks for the replies guys, much appreciated. Within reason, is it safe to drive until I can get her booked into a garage later this week?
Take it easy and you should be OK, less risky if it is a worn CV joint than a broken spring
Andyk likes this post
Agree should be OK to drive short term, just don't drive like you stole it or a rental car...Timtnx wrote:Take it easy and you should be OK, less risky if it is a worn CV joint than a broken spring
Thanks for all the replies, Windy is booked in for her inspection/repair.
Quick update, it was a broken spring
bigjase1972, 'Old'SeaDog and Andyk like this post
Springs a common fault on the Wind.
And anti-roll bar bushes..shock absorbers too
» noise inside car
» Adjustment / Greasing of Roof Lock Point
» Bleeping noise
» Tyre Sizes
» Tappet noise
» Bleeping noise
» Tyre Sizes
» Tappet noise
