Bleeping noise
Bleeping noise
I drove over a speed hump slowly and my wind bleeped,no warning light,just a bleep....any ideas?
portsoy wind- Set the stereo
Re: Bleeping noise
Do you have any parking sensors fitted?
Re: Bleeping noise
Reverse parking sensors should only energize when the car is put in reverse.
I bet you were almost on low fuel, and by going over the speed bump caused the low fuel beep to operate.
Re: Bleeping noise
My sensors have bleeped when not in reverse but only a couple of times.
Re: Bleeping noise
Barbs wrote:My sensors have bleeped when not in reverse but only a couple of times.
Do you have front ones as well?...as they obviously would not work through reverse.
Re: Bleeping noise
No just at the back. Not worried as its only happened a couple of times. Can't be fuel sensor as my fuel never gets less than a quarter of a tank.
Re: Bleeping noise
No parking sensors fitted and fuel was between quarter and half but low fuel warning was my thought, it was a decent sized ramp and perhaps i was just a bit speedy.....thanks for replying folks.
Re: Bleeping noise
Still think it could be your float switch in the fuel tank jumping, if you bounced hard.
Moral: take it easy over the speed bumps
Re: Bleeping noise
Yep Colin, i agree....lesson learned!
Re: Bleeping noise
At least in a Wind speed humps are just an inconvenience. Lots of humps my way but never had a bleep from the Wind.
My TF would occasionally ground unless I went really slowly & I had so many grounding problems with my 2001 V6 Alfa Spider that I ended up spending £250 having a bespoke centre section made for my exhaust system. Took out two of the 4 cats so it sounded great & just about passed MoT emissions as long as a sympathetic tester was prepared to give it a few tries!! My tester owns a Firebird so he knows all about emissions!!!!
» Tappet noise
» noise inside car
» Tyre Sizes
» Whistling noise from drivers window
» Engine horn noise and DLR install.
» noise inside car
» Tyre Sizes
