Adjustment / Greasing of Roof Lock Point
Adjustment / Greasing  of  Roof  Lock Point Empty Adjustment / Greasing of Roof Lock Point
Post by Etienne Wed 19 Oct 2022 - 12:37
Hi all, it must be possible to adjust the tension of the roof locking system....
When closed,I hear a knocking sound in the area above the windscreen.
I read somewhere that a noise in that area can be solved by greasing / adjusting the locking points.
I can't find where / how to adjust this lock ,... (increase the tension...)
Has anyone done this ?
A   1.2 / 2010    Wind Owner from Flanders- Belgium
Etienne
Adjustment / Greasing  of  Roof  Lock Point Empty Re: Adjustment / Greasing of Roof Lock Point
Post by Barbs Thu 20 Oct 2022 - 17:14
Etienne wrote:Hi all, it must be possible to adjust the tension of the roof locking system....
Hi, the car just needs some silicone spray where the latches above the windscreen.
Post by Etienne Thu 20 Oct 2022 - 18:43
Thank you for the reply. I 'll try that... Fingers crossed.  Razz
Etienne
Post by Barbs Thu 20 Oct 2022 - 23:05
It works honest.
Etienne likes this post
Adjustment / Greasing  of  Roof  Lock Point Empty I works!
Post by Etienne Fri 21 Oct 2022 - 9:31
Thank you very much for the tip. I cleaned the points, then sprayed them, including the rubber joints and all. Now I enjoy "The sound of silence". ( Not the Moody Blue's ...)
Tumbs up !
Etienne
Adjustment / Greasing  of  Roof  Lock Point Empty Shock absorbers
Post by pineapple Thu 27 Oct 2022 - 8:38
Hi all,
Had my front shock absorbers replaced a short while ago. Have noticed that my steering seems a little off, like tyres need air. Has anyone else had this problem?  Thanks
pineapple
Post by Etienne Thu 27 Oct 2022 - 12:42
I advice to have your wheel alignment checked in a garage. Measuring is knowing
Etienne
Post by pineapple Thu 27 Oct 2022 - 14:25
Thank you, I’ll get it checked out
pineapple
