Dead Wind, fixed
Dead Wind, fixed
Had a strange one today, car started as normal, drove the 16 miles to work, no issues.
However when I came to start it this afternoon, the car wouldn't unlock with the key, opened the door manually, put the key in ignition, nothing !!
Not even a light on the dashboard, strangely both the horn and the dashcam worked (runs of 12v socket), and I know the battery is good.
After much head scratching and looking on Renault forums, the twingo 133 forum suggested, disconnect the earth terminal from the battery for 10 minutes, so I did this and bingo it worked !!
It's a reset for the ECU, I'm going to get my mechanic to run a diagnostic check, but hopefully it's a one off incident.
BobbyA- Set the stereo
Re: Dead Wind, fixed
Too many electronics in these modern cars!!
I had a problem with my lights.
I unwittingly cured it; a bit like your solution of disconnecting the battery; by pulling all the lighting fuses which forced the "lighting ECU" to reset itself & work properly.
I didn't even know the lights were controlled by a mini computer; I just thought that it was via simple physical switches; but was advised by a main dealer that that was the case.
Pity I'd already wasted £140 on a new lighting switching unit!!
Glad you are back in action.
» windows problem fixed
» Totally dead
» Another Dead Collection
» Wind not so good in the wind?
» Totally dead
