Roof issue
Roof issue Empty Roof issue
Post by Renkev on Fri 22 Feb 2019 - 20:41
New on here and looks fantastic forum.
Been the proud owner of a WInd since last March 1.2 Collection TCE and absolutely love it.
Open top is tremendous UNTIL TODAY ????
Tried to open roof as normal and comes up check roof and windows go down about an inch.
I decided to leave it an hour and tried again this time on dash it shows roof opened and one dash on display
I lock roof and this displayed on dash until I drive then I get beeping every 30 secs with roof cycle finished.
Any thoughts?
I'm thinking sensor, electrical gremlin.
Was working spot on as usual on Thursday.
Thanks in advance.
Renkev
Roof issue Empty Re: Roof issue
Post by Barbs on Fri 22 Feb 2019 - 22:22
The roof can be sensitive if not on the flat. The other issue could be dirt in the hinge mechanism.
Can you give us more information
Post by Renkev on Fri 22 Feb 2019 - 22:34
The roof was being operated in no different an area than usual.
If it is dirt how can I remedy this if I can't open it?
This hasn't happened before in the 11 months I've had car.
I'm planning on taking to a garage on Tuesday for a look over as my warranty seems to cover electrical and sensors.
Renkev
Post by Barbs on Sat 23 Feb 2019 - 7:06
I had a problem with the roof before we went to International meet in France. I posted the solution to my problem on here somewhere will see if I can find it.
Post by Renkev on Sat 23 Feb 2019 - 8:21
Ok thanks for your help, appreciated
Renkev
Post by Mistydogblue on Sat 23 Feb 2019 - 12:38
The windows going down is the first part of the cycle before the boot or roof engages. As the windows are not going down that would suggest a fault in one of the windows or a sensor as you have suggested. It is unlikely to be dirt in the hinge mechanism. Check if both windows are operatng normally.
Post by Renkev on Sat 23 Feb 2019 - 13:11
Both windows are absolutely fine when working independently from the roof.
Renkev
Post by Mistydogblue on Sat 23 Feb 2019 - 14:00
The roof mechanism is so complex it is very difficult to pinpoint the fault through a forum. In addition to various sensors there will also be an ECU for the roof. Water inside the windows or excessive water around the boot electrics could cause a problem. Have you tried putting the windows down from their switches and once down try to open the roof.
Post by Renkev on Sat 23 Feb 2019 - 14:07
Ok I will try this with the windows.
After it has been raining I have sometimes had a little drip inside the window.
Renkev
Post by Renkev on Sun 24 Feb 2019 - 9:23
Ok I have tried putting windows down one at a time (so both open) then try to open the roof.
What happens is the boot part (sail) lifts about 1 inch then check roof comes on the display.
I am able to then push forward on the button to put it back and I can then put windows back up and lock the roof.
On the display on dash it says roof opening and 1 block.
If I drive it, it then displays ROOF : CYCLE FINISHED and will bleep intermittently.
Renkev
Post by Renkev on Sun 24 Feb 2019 - 10:00
UPDATE
Issue with roof has been rectified.
There was a very small stone that was jammed between the rear window and the first part of the boot. I managed to free this and hey presto it's back working.
Special mention to the Mrs who spotted this. Lol.
I'm really not sure how it got there and in addition managed to lodge itself in.
Renkev
Post by Mistydogblue on Sun 24 Feb 2019 - 12:02
happy days. If it had been part of the boot motor or sensors you would have been looking at a pricey fix.
Post by Barbs on Sun 24 Feb 2019 - 12:34
Great to hear it is sorted.
The forecast was a for sunny weather this weekend but we have misty conditions.  Lets hope it improves tomorrow it's time Blue boy saw the sea.
Post by Renkev on Sun 24 Feb 2019 - 17:14
Have had top off all day. Cracking day here.
Renkev
Post by Renkev on Sun 28 Apr 2019 - 21:13
Back to problem with roof again. 2 sensors replaced worked perfect for 2 weeks and doing exactly same as before. Tries to open and windows go down an inch as lid tries to lift. The 2 sensors replaced were either side of the lid. I now believe there is a 3rd along the boot lid. The dealers know very little and in general no-one appears to know much.
The guy I got to do it has diagnostic equipment but no error codes. He took a punt on the 2 sensors after speaking to Renault who then sent him a diagram showing the 3rd one. Strange that it did work for 2 weeks though.
He has taken then back off and refitted them as he says they have magnetic connections but still no joy.
Renkev
Post by johnwkey61 on Fri 7 Feb 2020 - 20:54
Did you solve the issue? As mine is doing almost the same.
johnwkey61
johnwkey61
Post by Renkev on Fri 7 Feb 2020 - 21:03
No I haven't done anything since my last post. I'd assume it will be the 3rd sensor.
Renkev
