Water leaking inside my Wind
Hello all, I just got my Wind during the summer and all was terrific. Now that we’re having these winter rains, I noticed a lot of water on the floor, behind the passenger seat. Not sure what could cause this (clogged water drainage system, leaky door seal…) so I thought post this here, in case someone had a similar issue. More info:
I believe water is coming either from the top of the passenger door, or from the right side of the roof / rear window,
In the interior, all of the carpeting behind the front seat is damped and wet on the floor,
There’s a lot of leafs flying around so it could be indeed clogged, but I don’t see any dirt in that area.
Thank you!
Thank you!
Pedrumond- Started the engine
Re: Water leaking inside my Wind
Are you sure your passenger side window is going all the way up to the top when you are closing the door? If not you will need to do the window reset.
Press window down and leave button pressed for 10 seconds once it’s all the way down, then repeat putting the window back up leaving the button pressed for a further 10seconds.
You may have to do this a couple of times for it to work.
'Old'SeaDog and Pedrumond like this post
Really good suggestion bigjase... I was never sure why, but random window "drop" was quite a frequent occurrence on mine too.
The reset always cured it
Barbs, bigjase1972 and Pedrumond like this post
Thank you both! I also try cleaning the gutters and rubbers around that area. Will also try the resetting of windows
bigjase1972 and 'Old'SeaDog like this post
» New cam belt and water pump
» noise inside car
» Replacement Cambelt/Timing belt and water pump
» LHD Lights
» noise inside car
» LHD Lights
