Timing belt replacement on a 1.2
Are there any special tools required for replacing the timing belt on a 1.2 or is it a case of line up marks on the crank and cam?
mdw- Took the roof down
Re: Timing belt replacement on a 1.2
I paid a garage but I know it is easier with a 1.2 rather than the 1.6.
Locking tools are required.mdw wrote:Are there any special tools required for replacing the timing belt on a 1.2 or is it a case of line up marks on the crank and cam?
Instructions here. http://replace-timing-belt.com/how-to-replace-timing-belt-on-renault-twingo-2-1-2-tce-2007/
Cheers, that doesn't look too bad. Pin through the flywheel then mark up the belt and pulleys.
Andyk likes this post
» Replacement windsceen
» Cam Belt or Timing Chain
» Cam Belt...Again!
» Cam Belt Change
» New cam belt and water pump
» Cam Belt...Again!
» Cam Belt Change
