MPG. is rubbish!
Johno.0
jmee54
MPG. is rubbish!
Hi all,
My 1.2 seems to be averaging 35mpg now. I am sure it was around 40 when I bought it, which in my mind is pretty rubbish, so 35 is the same as I get from my motorhome.
Is there anything I should be looking at to improve this abysmal fuel economy? Are there any modifications I can do to improve it?
jmee54- Put the sunglasses on
Re: MPG. is rubbish!
I had a judder when pulling away in first gear which I haven’t had for what seems to be ages now! However, because of this I went through the ignition system replacing everything, then fuel line, etc... and the other day I got just over 40 on mpg, (1.2 here as well). Not entirely sure what I replaced might have affected the fuel economy, maybe it all did but it could be worth looking there? I’ve noticed better fuel economy for a few days now, and I’m a very enthusiastic driver.
Getting 45.3mpg....according to the read-out anyway....
Mine's a 1.2 as well, so 35mpg is seriously low. Have you had it serviced recently?
An average of mixed driving for my 1.6 is about 34mpg which I find reasonable considering the low overall gearing & the close ratio gearbox. Let's face it the 133 1.6 engine was good in it's day re performance but it is pretty long in the tooth re fuel efficiency.
BUT: The 1.2 was Renault's early move into efficient tiny turbos so; unless you are really pushing it 35 mpg does seem poor.
The suggestion of checking out the ignition system is a good one. I noticed a difference on mine after changing plugs & coil packs. Renault recommend plug changes at 36000mls but no time limit unlike say the air filter recommendation which is 54000 mls or 4 yrs. Personally I change my air filter much more often which could be another area for you to look at.Hope you work it out.
I change my air filter every 3000 miles, I’d never leave it that long. I suppose that’s good in a way though as it means things are built to last longer... I hope.
Is that 3000 or 30000miles?
If it's 3000 it takes me back to my MGBs when I had to get out the grease gun on the suspension & steering every 2500 mls!
The service light has just come on and the car was serviced a year ago when I bought it. 45mpg would be great. To be honest, apart from the odd rush of blood, Cornish lanes are not too conducive to over spirited driving - tractors joggers and horses have caused brown trouser moments several times, so it would seem that something needs looking into. Should I just start replacing parts as mentioned above (Johno.0) and hope for the best (can I reset the service light?) or do I need to get it plugged into some technology? Difficult under the present circumstances.
This is the link for the service light reset: https://youtu.be/85t6kpuEw_M
I tend to service the car myself as I don’t always trust that a full service means a full service if you know what I mean.
I’ll only take it to a garage if I am unable to do it myself, like engine removal or new clutch, etc... I would have thought you’d see an increase after a service. I always “splash out” on new parts for my car as I do think you get what you pay for! Let us know how you get on.
Johno: I identify with that. I also do everything I can on the driveway myself.Johno.0 wrote:This is the link for the service light reset: https://youtu.be/85t6kpuEw_M
Some garage's description of a "full service" can be debatable to say the least.
Re Jamee's driving conditions: Even though you aren't going very fast I guess you must spend a lot of time in the lower gears which can impact significantly on your mpg.
In terms of MPG have you checked tyre pressures as they are often forgotten about and can have big impact. Also with the good weather has it been a lot of driving with roof/windows down and air con on? All the little things can add up alongside a proper service to change fluids, filters, plugs etc
D- Cruising down the highway
My mpg is always around 42 for the 1.2 and around 36 for the 1.6, same roads, same speeds etc, so around 17% higher for the 1.2.
Oil filter, oil, air filter. What else would you change in my position? Plugs. coil pack?
PS. I have been driving with the roof down over the last few weeks, but only down to the beach 40mph max and the mpg has been 35 for some months now - with same sort of driving. I will give the tyres a check too.
