Headlight bulb replacement
Headlight bulb replacement Empty Headlight bulb replacement
Post by BobbyA on Fri 3 Aug 2018 - 0:06
Has anyone changed their headlight bulbs not impressed with the standard ones at all, looking for recommendations and how difficult are they to fit.
BobbyA
Headlight bulb replacement Empty Re: Headlight bulb replacement
Post by Barbs on Fri 3 Aug 2018 - 12:21
I changed mine to the Philips white vision Xenon effect headlight, it did make a difference but when we went to the French meet a couple of years ago I used the light deflectors and I think a bit of residue remained on the plastic headlamp and the brighter light may of burnt the lens.  Having said that it is possible that something just hit the headlamp I have some new headlamps but they are sat in a garage in Kent.  (@Araf i will get down soon to collect them)  As for fitting them, I went round to my local garage and they sorted them for me, they claimed they were easy.
Post by pittstop on Fri 3 Aug 2018 - 15:20
EASY!!
Must be my old stiff fingers but I found fitting bulbs a right fiddly job.
When I switched on the lights afterwards; good thing I was pointed at the garage door at the time; I discovered I had actually mis-positioned one of them & the beam was all over the place.
Have to say after a change to Halfords bulbs with an alleged increase in power of 130% I haven't noticed much improvement in night vision.
Post by BobbyA on Fri 3 Aug 2018 - 17:14
BobbyA
Post by Barbs on Sat 4 Aug 2018 - 8:11
If you go for them it will be interesting to see what you make of them I think one of the German Winds has used something like that will see if I can find the post.
Post by Barbs on Tue 7 Aug 2018 - 8:05
Headlight bulb replacement Screen10
This is one of the French Winds
Post by knebby on Tue 7 Aug 2018 - 19:00
Yes, the lights are awful. I too changed to the Halfords (alledgedly brighter) ones but didn’t notice the difference.
