Headlight Restoration
If like me you find that the front view of your Wind is spoilt by dull and patchy headlight lens, I can recommend the Auto Glym kit.
Autoglym Headlight Restoration Complete Kit https://www.amazon.co.uk/dp/B015OOVIRA/ref=cm_sw_r_cp_apan_glt_fabc_ZY7D1AG3695B5D4JYRVY?_encoding=UTF8&psc=1
It's a bit scary as they get a lot worse before they get better but be brave and follow the instructions. Very happy with results . Will try and post pic
s
s
Mac- Set the stereo
Barbs, 'Old'SeaDog and fordprefect4 like this post
Headlights
Very nice. I got mine done.20.00 per headlight. I was fed up spending many years (it felt like) handling headlight with indifferent results. Yours have come up a treat.
fordprefect4- Took the roof down
Re: Headlight Restoration
Yes, they are still not perfect but then again, the car is 12 yrs old ;-)
Mac- Set the stereo
Yep. Same with mine bit soooo much better
nice dont forget to get some anti uv wax, treat the headlight with it every couple of months otherwise you will be doing it again in a year
as i did with my mothers
moggie007- Put the sunglasses on
Yes that's right. I use a turtle Wax which has UV protection every couple of months too.
I should have mentioned that although it doesn't come with the kit, I had read about the UV issue and so had bought a can of "Clear coat" spray lacquer which is meant to protect it from UV. Appreciate the comments / concerns though
Mac- Set the stereo
