Dashboard illumination
I'm new to the forum and wonder if anybody can help with a couple of problems I have with my wifes Renault Wind. During daytime there is no illumination on the binnacle ie speedo and rev counter. We end up using the side lights during the day to light up the binnacle. The computer shows the illumination as maximum. In addition to that some of the heater controls do not light up at night. I assume one of the lamps has gone but can't see how to access them. Any help would be appreciated.
RogerS- Started the engine
Re: Dashboard illumination
Welcome Aboard the Forum.
The dashboard visibility is a design fault on the Wind exacerbated by how deep set the instruments are.
When, a few years ago, I followed this up with a main dealer & Renault's on line enquiry facility they offered no cure.
Driving round on sidelights seems to be the only answer.
Why not drive on sidelights plus fog lights which would look like daytime running lights?
By the time I'd thought of this I'd already fitted DRLs as can be seen in the picture of my car.
pittstop wrote:Welcome Aboard the Forum.
I must admit to driving with sidelights and fog lights in poor light conditions..
My latest plan is to fit white LED fog lamps...but I'm not sure if they'd be legal...?
I rewired the fog lights on my MGTF so they were ignition linked, rather than connected to the lighting circuits, like DRLs.
Dead simple just straightforward 12v electrics
I then put in LED bulbs as you suggest.
It worked really well & no complaints from MoT tester.
I wanted to do the same for the Wind but the electronics; I believe the lights are controlled by their own mini "ECU"; made unlinking from lighting circuits & linking to ignition a task I decided was beyond my auto electric skills.
Instead I fitted aftermarket DRLs linked to the power socket feed which is ignition linked.
pittstop wrote:I rewired the fog lights on my MGTF so they were ignition linked, rather than connected to the lighting circuits, like DRLs.
Yes, I remember that you've also fitted a switch to the DRLs from the 12v socket ?
In case the MoT objected to my DRLs; I believed they were a little further in from the outside edges of the car than specified on new cars; I inserted an in line fuse between the power source & the DRLs.which I could just pull out to disable them. It also protects against any short circuit should my wiring chafe against any metalwork.
Having done this I then read this extract from a letter from the DFT to someone who had queried the fitting of after market DRLs.
"Currently DRLs are not inspected as part of the MOT and retro-fitting DRL
will not result in a test failure regardless of their placement. If
future changes to the MOT scheme bring DRL within the scope, consideration
will need to be given as to how to treat retro-fitted DR"
So no problem there for now.
Dashbosrd illumination
Hey there, I can't halp with the technical side of things, but can give you I go about driving with your fogs on. I was told, in Scotland, it could get you 3 points on your license and a fine - as for England that might not be the case, but the advice seems to be don't drive with them on...
https://www.askthe.police.uk/content/Q400.htm#:~:text=XYZ-,Q400%3A%20A%20lot%20of%20cars%20have%20their%20fog%20lights%20on,can%20obscure%20your%20brake%20lights.
Roadster- Set the stereo
Roadster wrote:Hey there, I can't halp with the technical side of things, but can give you I go about driving with your fogs on. I was told, in Scotland, it could get you 3 points on your license and a fine - as for England that might not be the case, but the advice seems to be don't drive with them on...
Thanks for the information Roadster....I'll bear this in mind in future, it's definitely not worth the risk of attracting the unwanted attentions of the Boys in Blue...!!
Roadster likes this post
Recently saw a weird take on DRLs.
A car I was following had LED DRLs; similar to mine; fitted to the rear of the car above the number plate with the LEDs shining "backwards".
That can't be legal!
pittstop wrote:Recently saw a weird take on DRLs.
I've seen white LED number plate bulbs too...they don't look at all right...
I've noticed that Halfords sell them...so must be legal
Technically speaking no LED bulbs are not legal in UK vehicles. There is specific and detailed legislation that states vehicle bulbs carry a British standard mark (usually the E Mark) and/or be certain watts. LEDs do not have that Mark and the legislation was never written with them in mind so at best it is a grey area.
D- Cruising down the highway
