Switch to dip headlight beam location
Does anyone know where this switch is located (if existent) had a quick look and couldn't see it?
Re: Switch to dip headlight beam location
What do you mean?
With the headlights on, they are dipped. Pull the left stalk towards you for main beam, and pull it towards you again to go back on dipped.
If you only want the sidelights only, the end of the left stalk twists.
For the record, the next part of the stalk also twists. Up (I think) for front fogs, up again to turn them off. Down for rear fogs, down again to turn them off.
In the twingo I had a switch to change the height of the beam that went 0-4 seems odd I couldn't see one.
With you now. Officially it's needed for towing, and as the Wind is not type approved for towing, there's no need. I guess you found the traction control switch, while you were hunting.
Anybody else think the beam of the headlights is actually set too low?
I thought it was just me. I don't drive much on unlit roads but when I do I am forever switching to full beam just to see a bit further down the road
Have any of you folks changed the bulbs over? I have osram night breakers in there and have no problems, I was just looking for it out of interest.
Thanks Araf!
Thanks Araf!
I haven't but was thinking about changing them just didn't know how much difference it would make
The standard bulbs in both my Renaults were awful, couldn't see any further than a metre ahead the reviews speak for themselves.
I've got some more powerful bulbs in from Halfords. Cant remember what they were but supposedly 85% brighter but don't seem to make a huge difference. I think the beam is just too low, not necessarily not bright enough.
If you think it's too low, adjust it up. That would be the same for all cars, as towing adjusters just move them down further.
My problem with brighter lights, is that if everyone uses them, you're back to square 1. And yes Barbs, the idea is that you use main beam, when nothing is coming towards you, and dip your lights for them to pass.
Araf wrote:If you think it's too low, adjust it up. That would be the same for all cars, as towing adjusters just move them down further.
I do that but sometimes it feels like I am the only one dipping headlights....
That's because there are too many selfish people who only think of themselves, and put illegal strength bulbs (over 100w) in their headlamps, dazzling all oncoming traffic. If you do likewise, they will just move to 140w or even 200w bulbs.
Or fit xenon lights without the proper projectors that's one of my pet peeves, I doubt they can even see Infront of them
New lamps bought for dipped headlights. Have looked at the details in the manual posted by Mkstevo. If anyone has changed them please tell me its easy. Last time I changed a light bulb in a car it was a Triumph Dolomite now that was easy....
They should be held in place by a hinge lift the hinge off and pull the connectors off then take the bulb out and stick your new one in.
» Hazard switch
» Hazard switch
» Reverse light switch
» Door closed switch faulty
» Location of oil filter
» Hazard switch
