Condensation
Condensation Empty Condensation
Post by johnwkey61 Fri 13 Dec 2019 - 19:42
I had an issue the other day, it was very frosty and I clicked the defrost button (if that is what its called). The windscreen started clearing I scraped the ice off of the windscreen and side windows. Pretty soon the windows were clear. Then I turned off the defrost button and almost immediately the inside fogged up badly. Is there a knack to setting the climate control? The fog wouldnt clear so had to put the defrost on again which took a while for some reason.
johnwkey61
johnwkey61
https://sites.google.com/site/johnshouse61/home
Condensation Empty Re: Condensation
Post by Barbs Sat 14 Dec 2019 - 7:49
I have mine set to auto and just change the temp. When I have used the windscreen heater I have just left it on till the car feels warm.
Post by pittstop Sat 14 Dec 2019 - 15:02
When in full Auto mode the Auto Aircon system on the GT Line decides where to send the airflows to the cabin. This is rarely to the screen & usually to just the dashboard vents sometimes causing irritating drafts.
Instead of having the system set to full Auto I have overridden the  the air flow setting to screen & floor simultaneously. Little air comes from the dashboard vents on this setting which eliminates the drafts mentioned above.
The system will hold this setting when you press & later release the demist button.
So when starting up I press the demist button & let it clear the screen. Once the screen is cleared I press the demist button again & the system defaults to my setting of screen & floor. This warms the car whilst maintaining some airflow to the screen to keep it clear.
I maintain this setting all year round as heat or cooling to screen & floor simultaneously gives a good temperature balance throughout the car at all times.
Last edited by pittstop on Sat 14 Dec 2019 - 15:03; edited 1 time in total (Reason for editing : spelling!)
Post by johnwkey61 Sat 14 Dec 2019 - 23:04
Thanks for all your help 👍
johnwkey61
johnwkey61
