Front vision
Front vision  Empty Front vision
Post by Sweeney Thu 14 Nov 2019 - 14:04
Just wondering if any Wind drivers run a dashcam for front vision,I don't think a rear one would really see a great deal.. Open for comments etc
               Sweeney
Sweeney
Front vision  Empty Re: Front vision
Post by Mistydogblue Thu 14 Nov 2019 - 14:16
Yes, I have installed a rear view mirror that incorporates a dashcam, rear dashcam/reversing camera and sat nav. I have also used a hard wire kit to power it from the cigarette lighter fuse and have run the wires up the door pillar and along the top of the windscreen panel. The one downside is that the dashcam interferes slightly with the radio reception but I have tried other dashcams and they also do the same. I think the problem is having the aerial build into the rear window which is not as efficient as an external aerial.
Post by Sweeney Thu 14 Nov 2019 - 14:55
Thanks for the reply Cheers
Sweeney
Post by DarrenJ Thu 14 Nov 2019 - 17:57
Sounds like you have the full set up that I’d like. Less worried about radio interference as rarely use it. Have a mini USB stick that has lots of music on it instead.
Seen a few rear view mirrors that combine that amount of functions, but couldn’t decide which was best.
Is the rear view mirror a replacement or suction on to existing one?
DarrenJ
DarrenJ
Cruising down the highway
Post by Mistydogblue Thu 14 Nov 2019 - 19:52
It's a replacement mirror _ Junson that I got on Amazon for about £150 but I think they are currently unavailable. I also have another one on a different car that clips to the existing mirror and it is quite good also. It is a Kkmoon brand and is available on Amazon for around £100
