Horn is not right! ANYONE?
Horn is not right! ANYONE? Empty Horn is not right! ANYONE?
Post by jmee54 on Mon 13 May 2019 - 15:12
I'm not sure if this is technical enough to be posted here! My horn is sounded like a strangled cat so I though I would give it some attention. Trouble is, I can't find it! It sounds like it is driver's side down at the bottom somewhere. Any ideas where and how to get to it, please?
jmee54
Horn is not right! ANYONE? Empty Re: Horn is not right! ANYONE?
Post by jmee54 on Fri 31 May 2019 - 11:44
Squawk, Squawk! has anyone worked on their horn?
jmee54
Post by Mistydogblue on Fri 31 May 2019 - 12:09
Hi the horn is located behind the drivers side wing. To get at it you need to remove the wheel and then remove or pull back the plastic inner splashguard panel. It is held on with a few screws and plastic panel clips. The horn has an adjustment screw (covered by a bit of rubber as i recall). Even when working properly the horn is not great.
Post by jmee54 on Fri 31 May 2019 - 15:35
Thanks Mistydogblue, that has saved me stripping out half the front!
jmee54
Post by Mistydogblue on Fri 31 May 2019 - 19:20
You are welcome. I should have clarified that it is behind the front part of the wing.
