Clutch Shudder on 1.6
Clutch Shudder on 1.6 Empty Clutch Shudder on 1.6
Post by pittstop on Mon 29 Apr 2019 - 15:16
Have been sensing a little shudder recently on releasing the clutch from standstill & whilst reversing up my sloping drive.
Deliberately slipping the clutch a few times made no difference which eliminated the likelyhood of clutch plate contamination.
Thank goodness for that as it could have been a sign of a failing crankshaft oil seal.
Then looked at top engine mounting (drivers side).
Checked tightness of bolts holding mounting to engine & body One was slightly not as tight as the others but nothing to write home about.
Then tried the nut in the centre of the mounting itself & lo & behold it was loose.
Gentle tighten up & shudder gone.
Would that all problems were that easily fixed!
