Alarm help
Alarm help
My alarm keeps going off when I get into the car or open the boot. I’ve even tried removing fuse 6 which the map shows as alarm amongst other things as a quick fix until I can get to the bottom of it but the alarm still goes off! Any ideas?
Colin7834- Started the engine
Re: Alarm help
I would suggest you check the condition of your car battery as if this is not fully charging it can cause the alarm to go off. If the alarm has a build in battery pulling the fuse could trigger the alarm. I would also check the bonnet sensor as these can be faulty if the pin does not close enough. Use something to slightly build up the thickness of the stopper. If all else fails it is relatively easy to disconnect the alarm. Pull off the panel on the boot (where the lock is) 2 screws and a few push clips and you will see the alarm. Disconnect the wiring plug.
Re: Alarm help
Forum to the rescue again. Had problems with alarm overnight, went off 4 times. Then this morning it was going off every few minutes. Phoned my guy who does service on my cars he came out within 30 mins to check the battery. Yep one cell gone. I don't do many miles in Blue Boy so battery will be replaced later today or tomorrow morning. He said a good run would help but battery will eventually need replacing as it is the original one.Mistydogblue wrote:I would suggest you check the condition of your car battery as if this is not fully charging it can cause the alarm to go off. If the alarm has a build in battery pulling the fuse could trigger the alarm. I would also check the bonnet sensor as these can be faulty if the pin does not close enough. Use something to slightly build up the thickness of the stopper. If all else fails it is relatively easy to disconnect the alarm. Pull off the panel on the boot (where the lock is) 2 screws and a few push clips and you will see the alarm. Disconnect the wiring plug.
Re: Alarm help
063 battery type. Loads on eBay starting from about £34
Re: Alarm help
bigjase1972 wrote:063 battery type. Loads on eBay starting from about £34
Re: Alarm help
Mine has started doing something similar very intermittently, with the alarm sounding when the passenger door is opened first after unlocking...never the drivers door or boot ??...Have had the battery condition checked by my friendly garage and all appears ok. Then I remembered that the only manual door lock is on the passenger door..have applied WD40 amd silicone grease to the lock....fingers crossed.
