Question re engine bay
Question re engine bay Empty Question re engine bay
Post by renton beersworth on Fri 11 Jan 2019 - 10:43
I have had my Renault Wind now for about 8 weeks and delighted with everyting so far. Checking the levels under the bonnet and saw a piece of
polystyrene, black colour in the top left hand side corner. Not sure why its there, maybe something to do with soundproofing or to prevent any debris entering then blocking
drain areas, either way there is not a matching piece in the top right hand corner. Question is, was there ever a piece in the top right or is it missing. Under bonnet detectives
may be able to solve this I hope.  R.B.
renton beersworth
Question re engine bay Empty Re: Question re engine bay
Post by pittstop on Fri 11 Jan 2019 - 14:19
Just had a look at my 1.6 & it is just the same with the polly moulding drivers side only
Looked up how to remove a front wing on Dialogys & there is an image of the passenger side with no poly moulding so we are not missing anything!
I notice that the intake vents for the air con are also on the drivers side. Maybe the moulding has got something to do with preventing water running into them.
Anyone got more info?
Last edited by pittstop on Fri 11 Jan 2019 - 14:39; edited 1 time in total (Reason for editing : update)
Question re engine bay Empty re polystyrene bit missing (or not)
Post by renton beersworth on Sat 12 Jan 2019 - 11:02
Hello Pitstop, Thanks for the swift reply. I agree with you that the part must be something to do with stopping the ingress of something.
At least I now know that I do not have a part missing. R.B.
renton beersworth
