How do i remove the rear window plastic trim?
I am getting loads of rattles from the black square trim inside the car. Does it just pull off?
Alex1197- Took the roof down
Re: How do i remove the rear window plastic trim?
Are you certain the noise is coming from that. The roof on the Wind is prone to making a rattle noise but a bit of grease in the catches above the windscreen normally sorts it.
Alex, yes it will pull off. It is held on with about 6 metal retaining clips.
Thanks both. It is def inside the car. I will put and vibration stuff behind it.
Both my Winds have a bit of a rattle from that back window trim, usually in cold weather and in both it disappears once the interior has warmed up.
I have just done my fix. I will let you know if it works. I did something similar on my laguna and the rattle went.
» Touching up plastic bumpers.
» Drivers window.
» Cut out on bumper trim
» Drivers window 2.
» Window drop
» Drivers window.
» Drivers window 2.
» Window drop
