USB - Browse by folder?
USB - Browse by folder?  Empty USB - Browse by folder?
Post by Segak1d on Wed 19 Sep 2018 - 17:42
Hi all, new owner here! Is there a way to skip folders rather than just tracks if using a USB stick in the USB port? I know the skip track button on the radio skips tracks, but can't find a button or way to skip through folders/albums? Thank you
Segak1d
USB - Browse by folder?  Empty Re: USB - Browse by folder?
Post by DarrenJ on Wed 19 Sep 2018 - 22:37
It might be different depending on how you have the folders organised on your USB.
For me when I look at the stereo display can see the track name but can filter by album title or artist. On the stereo either side of the central knob there are two large arrow buttons. Using those allows you to move/filter between the folder options.... or in this case move between Artist Name-Album Title-Track Title. I think it is in that order.
Once you are on the sub level you want can then use the central knob to skip to another album.
I’ll double check in the morning and repost if it is different.
DarrenJ
DarrenJ
Post by Segak1d on Thu 20 Sep 2018 - 19:10
Ok thank you, I will have a play tomorrow, I'm sure I had tried those arrows but I'll look again! I just have each album in its own folder so hopefully that's all I need to do
Segak1d
Post by Segak1d on Thu 20 Sep 2018 - 19:36
I just tried those arrows and still can't get it to work, they select between the USB logo, folder or track title but nothing I seem to do let's me skip to the next album/folder? Very strange!
Segak1d
Post by Segak1d on Sat 29 Sep 2018 - 10:35
I figured it out, I was doing it wrong! I was using the arrows but not the central knob. My bad! Thank you
Segak1d
Post by DarrenJ on Sat 29 Sep 2018 - 11:20
You can also use the scroll wheel (as alternative to central knob) on the stereo controls that are behind steering wheel on the wiper stalk side.
Much easier to use when driving to change tracks/albums
DarrenJ
DarrenJ
Post by Segak1d on Sun 30 Sep 2018 - 17:44
Thanks I'll try that out too
Segak1d
