ECU remap fitted
ECU remap fitted Empty ECU remap fitted
Post by Bunyip on Thu 30 Aug 2018 - 21:55
Just had a remap done on both the Clio and the Wind noticable change to power and significant change to mpg on both cars, also had replacement coil packs on both cars.
Very happy with the results remap done by Top Gear - Powerflow.
Bunyip
Bunyip
ECU remap fitted Empty Re: ECU remap fitted
Post by Keef on Sat 3 Nov 2018 - 19:48
Sounds excellent ! What power are you getting on the wind ?
Keef
Post by pittstop on Sun 4 Nov 2018 - 10:20
Reasonably priced re-maps seem to be available for the 1.2 but getting any meaningful/usable power increases for the 1.6 would seem to be not economically viable for most owners.
ECU remap fitted Empty Ref Remap
Post by Sweeney on Mon 5 Nov 2018 - 0:28
I don't wish to appear ignorant but what is a REMAP please
                 Sweeney
Sweeney
Post by pittstop on Mon 5 Nov 2018 - 12:24
The "map" is the software in your ECU which programmes how the engine runs. It adjusts things like fuel intake, ignition timing, etc depending on things like: load, how hard you depress the accelerator, temperature, etc to optimise performance in a wide variety of circumstances.
The "map" on a production car will always be a compromise between ultimate performance, fuel consumption, driveability, longevity, etc so a "remap" (reprogramming of the software) can alter the bias towards greater performance or greater economy etc without changing any mechanical bits.
As the 1.6 Renaultsport engine's "map" (programme) is already biased towards performance & high revs there is less scope to increase performance further by remapping whereas the 1.2 engine, in standard form, has more leeway for improvement.
Greater improvements in performance' particularly to the 1.6 would involve changes to mechanical stuff such as camshafts, exhaust etc & cost much more on a £s per BHP gain basis.
Post by Sweeney on Mon 5 Nov 2018 - 14:21
Thanks for the prompt and infomative explanation .
                Sweeney
Sweeney
