Service Intervals
Service Intervals Empty Service Intervals
Post by Huw (Barry The Renault) on Tue 14 Aug 2018 - 20:59
Hi - remind me where to find what is supposed to be done at the various service intervals will you guys. I know I've seen it on the site, and I know it can be found at Renault somewhere.
I'm pretty sure I haven't had all the work that  is supposed to done - only two major services at most from memory (since 2011).
Cheers
Service Intervals Empty Re: Service Intervals
Post by pittstop on Sat 18 Aug 2018 - 18:29
I got this info from Renault.
Yes plugs are not time dependent!!
MILEAGE & TIME SCHEDULED ITEMS MilesYears
Replace Engine Oil & Filter 180002
Replace Cabin Filter 180002
Replace Spark Plugs 36000
Replace Air Filter 540004
Replace Brake Fluid 720004
Replace Accessory Belt & Rollers 720006
Replace Timing Belt & Rollers 720006
Replace Coolant 900004
                                           MILES   YEARS
REGULAR SERVICE ITEMS       18000   2
Check & Lubricate Bonnet lock
Check Exhaust Pipe
Check Cooling System & Level
Check Brake/Clutch Circuits & Levels
Check Suspension: Joints, Mountings, Gaiters, Shock Absorbers
Check Tyres: Condition & Tread
Check Wear Brake Discs/Pads
Check Exterior/Interior Lights
Check Windscreen & Door Mirrors
Check Wiper Blades & Screen Washer
Check Fault Codes
Replace Remote Batteries
Check Instrument Panel Warning Lights
Reset Service Schedule Indicator
Last edited by pittstop on Sat 18 Aug 2018 - 18:38; edited 4 times in total (Reason for editing : more info)
Post by Huw (Barry The Renault) on Sun 19 Aug 2018 - 12:49
Awesome thanks :-) Will cross check. Until then I will hold off on criticising my local garage for not doing their job (egg/face lol).
H
Post by pittstop on Mon 20 Aug 2018 - 14:40
Just a thought.
No mention of check oil level there. I'm sure we ALL check weekly!!!!
That said the Wind goes between services with no topping up which is more than I can say for some of my previous cars.
Back in the day 250 miles to the pint was actually the norm for a 1275 cc Mini Cooper S!!
Also occasional squirt of silicon spray in the roof mechanism's "important little places" is good.
Post by Keef on Thu 23 Aug 2018 - 0:00
@pittstop wrote:Just a thought.
Where are the roofs important places ! The point where it connects to the windscreen ? =)
Keef
Post by Barbs on Thu 23 Aug 2018 - 6:49
Yes the two catches bit of silicon grease in there and no rattles from the lid.
