Removing the Radio Headunit?
Removing the Radio Headunit? Empty Removing the Radio Headunit?
Post by ElNumbre on Tue 6 Mar 2018 - 17:46
Has anyone ever taken out the radio headunit?
I can't see any obvious release points, and am therefore unsure if any special shims/tooling is required.
Removing the Radio Headunit? ZVYO496
Removing the Radio Headunit? Empty Re: Removing the Radio Headunit?
Post by ElNumbre on Fri 30 Mar 2018 - 10:21
Just a brief update, I discovered that the trim around the head unit pulls off. Then it looks like it's a case of using some shims to release the unit itself, but I've not got that far yet.
