Roof Key Dimensions
Roof Key Dimensions Empty Roof Key Dimensions
Post by Sandancer on Sun 13 Nov 2016 - 20:50
Can someone please post dimensions of the roof key. I don't appear to have one. If its just a long allen key, could you please advise the size.
Many thanks
Sandancer
Sandancer
View user profile
Roof Key Dimensions Empty Re: Roof Key Dimensions
Post by Araf on Sun 13 Nov 2016 - 21:50
Yes, it is just an allen key.  Not having the car any more, I cannot give you the size, but if you remove the rear Renault diamond, and the black plastic cover underneath, you'll see the hexagonal hole.  You may need a long series allen key to get to it, but if you have a set of keys, you should then be able to reach.
If you don't have a set, then these are cheap enough if someone else can't measure their key for you. Smile
http://www.ebay.co.uk/itm/9PC-EXTRA-LONG-BALL-POINT-END-ALLAN-ALAN-ALLEN-ALEN-HEX-KEY-SET-1-5MM-10MM-NEW-/152281627298?hash=item2374b13aa2:g:1X8AAOSwGXtXgpHw
View user profile
Post by Sandancer on Sun 13 Nov 2016 - 22:09
Thanks for your quick reply. I'll have a look at this tomorrow.
I don't need it, but its best to prepared just in case. Very Happy
Sandancer
Sandancer
View user profile
Post by Barbs on Sun 13 Nov 2016 - 22:53
Please don't leave it in the boot when you get one. If you NEED it, you can't open the boot to get it....
View user profile http://renaultw.in/d/?page_id=4981
Post by Sandancer on Mon 14 Nov 2016 - 11:03
Thanks for the tip Barbs.
Sandancer
Sandancer
View user profile
Post by Sandancer on Mon 14 Nov 2016 - 19:56
The Allen or Hex key needed in an emergency to raise / lower the boot lid if the power system stops for any reason is a 4mm Allen Key x approx 10cm in length. Nothing special about it.
Sandancer
Sandancer
View user profile
Post by Barbs on Mon 14 Nov 2016 - 22:43
Unless your roof fails, then the key is special. The noise it makes when not fully open or shut is really annoying.
Post by KatanaAl on Thu 17 Nov 2016 - 12:10
Geoff,
Good job my car had the key in the glove box yesterday.
Alan
KatanaAl
KatanaAl
View user profile
