Air conditioning
Air conditioning Empty Air conditioning
Post by LukeC on Fri 24 Jun 2016 - 17:40
Hi
I was speaking to a vehicle air conditioning specialist as I had an issue with another of my cars which is less than 2 years old; the air conditioning had packed in on it.
Apparently the systems are lubricated meaning they need running for around 5 minutes; approx every month otherwise the rubber seals dry out and crack causing untold problems; including compressor failure; thought id share this useful bit of information with you all.
Use it or lose it.
Air conditioning Empty Re: Air conditioning
Post by ElNumbre on Fri 24 Jun 2016 - 21:03
Also, if it does stop cooling, its worth getting the system inspected and pressure tested by a specialist, as its a sealed system so shouldn't need refilling unless its been holed or broken somewhere.
Air conditioning ZVYO496
Post by LukeC on Fri 24 Jun 2016 - 23:59
@ElNumbre wrote:Also, if it does stop cooling,  its worth getting the system inspected and pressure tested by a specialist,  as its a sealed system so shouldn't n
Ueah this guy qas great didnt charge me a penny as he couldnt fix it eed refilling unless its been holed or broken somewhere.
Post by Araf on Sat 16 Jul 2016 - 21:10
My dad doesn't charge me either. Smile
He popped around and topped up the aircon on our cars.
Post by Barbs on Sat 16 Jul 2016 - 21:13
Araf can I borrow your Dad please/?
Post by Araf on Sat 16 Jul 2016 - 21:18
Doncaster is a long old way for an 82 year old to drive, but he'd be up for it. Laughing
Post by Barbs on Sat 16 Jul 2016 - 21:21
Send him up Please. Is he any good at decorating?
