Windows auto up
Windows auto up Empty Windows auto up
Post by fink on Sat 9 Jan 2016 - 13:00
Hi guys, I have a problem that it appears a few others have had. The other day my drivers side window went down as normal when I opened the door, but did not automatically go back up. It will go back up if you press the window up button, but the auto feature is not working. I've tried the up and down for 10-30 seconds idea, but it hasnt fixed it. Renault want to charge 79 quid just to look at it. Any suggestions
fink
Windows auto up Empty Re: Windows auto up
Post by Barbs on Sat 9 Jan 2016 - 13:15
hello and welcome
the reset normally works. Have you followed the instructions on here?
have you tried opening the roof and closing it that might then reset it
Post by fink on Sat 9 Jan 2016 - 15:07
Yeah tried that too.
fink
Post by Araf on Sat 9 Jan 2016 - 15:49
I assume you tried the window reset with the door closed, not open?
It sounds like a sticky micro switch, which thinks one or other door handles has remained pulled.  I would look for them, and make sure you can hear an audible click from them when making and breaking.  I think the door handle assembly is a three figure sum, and there's no guarantee that it will fix the problem.
I have the opposite, the passenger window doesn't like dropping, when it's cold.  I can usually get mine to drop by hitting the door lock button, with the door open.  As the central locking makes it work, I wonder if the problem could be the alarm module, rather than the door lock?
Post by fink on Sat 9 Jan 2016 - 22:31
Yay...finally got it working....tried the up and down technique at key position 1 2 and 3...and it worked.
fink
Post by knebby on Sun 10 Jan 2016 - 8:30
Welcome to the Forum. Where are you and what have you got?
Post by knebby on Sun 10 Jan 2016 - 8:36
Post by colin565 on Sun 10 Jan 2016 - 10:24
In this icy weather you have to watch the window operation.
Before I open the door, I use a large deicer sprayed over the top and sides of window edge, before opening door.
If away from home, I use a pocket deicer that I carry with me.
Post by Araf on Sun 10 Jan 2016 - 11:09
@colin565 wrote:In this icy weather you have to watch the window operation.
I live where it's a lot warmer. Very Happy
Post by fink on Sun 10 Jan 2016 - 13:31
Hi Guys. I'm in West Sussex and am driving a Blue 1.2 GT Line.
fink
yeah has been icy a few days...thats probably what did it.
fink
Post by Araf on Sun 10 Jan 2016 - 15:19
@fink wrote:Hi Guys. I'm in West Sussex and am driving a Blue 1.2 GT Line.
I'm in Kent, and there's a couple more from south of London that get on here.
There's still too many Northern Monkeys though. Wink
Post by Barbs on Sun 10 Jan 2016 - 16:22
I saw another one today
Post by colin565 on Sun 10 Jan 2016 - 22:36
And some even further North than the Northern Monkeys  Razz
If this was 'game of thrones', I would class myself as way beyond the ice wall  Very Happy
