Windscreen washers not working
Windscreen washers not working Empty Windscreen washers not working
Post by Richard1 on Fri 18 Dec 2015 - 20:11
Here's hoping someone can help with this. My washers have stopped working, wipers still work fine but no washers, any ideas [/i]
Richard1
Windscreen washers not working Empty Re: Windscreen washers not working
Post by Araf on Fri 18 Dec 2015 - 20:58
No fluid?
Blocked jets?
Broken pipe?
Electrical problem - pump or fuse?
Post by Richard1 on Fri 18 Dec 2015 - 21:42
Full of fluid, no sign of any leaks. Suspect electrical fault
Richard1
Post by Richard1 on Fri 18 Dec 2015 - 21:43
All the fuses seem ok, I think it's the same fuse as the wipers
Richard1
Post by Araf on Fri 18 Dec 2015 - 23:28
Can you hear the pump when you pull the stalk forward?
Post by Richard1 on Sat 19 Dec 2015 - 8:30
No, would the pump be fed directly from the stalk, or is it controlled by a body control module? Thanks Richard
Richard1
Post by Araf on Sat 19 Dec 2015 - 22:57
Sorry, can't help with that.  I'm old school I'm afraid.
If you can't hear the pump, I would look to try a direct feed to it, to see if it is working.
My only suggestion if it is BCM controlled, is to try disconnecting the battery for 10 minutes, then re-connect.
Post by Richard1 on Sun 20 Dec 2015 - 8:45
Many thanks for your help
Richard1
Post by knebby on Sun 20 Dec 2015 - 15:42
A while back mine didnt squirt properly, i'd pull on the stalk, pump would be working, but no water then it would arrive after a while. Turns out it was a faulty stalk and two hundred and something quid for a new one.
Post by Richard1 on Sun 20 Dec 2015 - 15:48
Ouch! I hope it's not that. Booked into Renault Cardiff on Wednesday, hoping it will be covered under warranty
Richard1
Post by LukeC on Sun 20 Dec 2015 - 16:37
The stalks are universal? So you could pick one up with the correct connections for around £20 from a breaker
Post by Araf on Sun 20 Dec 2015 - 17:08
Not sure on them being universal, and even Twingo ones would probably have an extra function for rear windows, so may not be interchangeable.
Post by Richard1 on Sun 20 Dec 2015 - 19:38
Thanks for all the replies
Richard1
Post by Richard1 on Sun 3 Jan 2016 - 0:03
All fixed, a new pump fitted under warranty
Richard1
Post by knebby on Sun 3 Jan 2016 - 8:16
Good. Doesn't sound too expensive.
