Changing coil pack [1.2 TCE]
Requires;
Small ratchet
Torx 25 screwdriver
Tors 30 male socket
Take out 4 screws securing airbox there are 4 t25 screws two on the top and 2 about 5cm underneath those
[Image to follow ]
Unclip the air inlet pipe by pushing the two circular buttons in with one hand and shuffle it down with the other until its clear
Remove airbox by shuffling it out
Pull coils out of engine and disconnect leads
Firing order
1 to top left
2 to bottom left
3 to bottom right
4 to top right
Small ratchet
Torx 25 screwdriver
Tors 30 male socket
[Image to follow ]
Firing order
1 to top left
2 to bottom left
3 to bottom right
4 to top right
fordprefect4 likes this post
Re: Changing coil pack [1.2 TCE]
Unclip lead in coil pack by pushing the clip on the back up then lifting it out
Take out 4x T30 bolts holding coilpack in these are a bit rusted as they're touching 2 other pieces of metal inside the engine bay so approach with care are they're easy to strip the two screws on the left are also hard to access you can either remove the pipe or work around them using a bendy attachment on the socket
Reassemble coil pack (put some copper grease on bolts) connect leads and screw everything up
» 1.6 Coil Packs.
» Changing air filter [1.2 TCE]
» Changing bulbs
» Renault wind coil springs
» Changing spark plugs [1.2 TCE]
» Changing bulbs
