Car hesitates / splutters while pulling away
Car hesitates / splutters while pulling away  Empty Car hesitates / splutters while pulling away
Post by LukeC on Mon 9 Nov 2015 - 13:35
Engine light on; going to run diagnostics on it wendesday ; what you guys guessing at?
Im guessing spark plugs
Car hesitates / splutters while pulling away  Empty Re: Car hesitates / splutters while pulling away
Post by Araf on Mon 9 Nov 2015 - 14:26
Coil pack.
Get yourself a diagnostic tool.  They're not expensive.
Post by LukeC on Mon 9 Nov 2015 - 15:40
I have one coming for Wednesday; difficult to replace?
Post by Araf on Mon 9 Nov 2015 - 16:46
Nope. Usually easier to replace a coil pack than a spark plug.
Post by LukeC on Mon 9 Nov 2015 - 17:12
Cool man; just waiting on the diag equipment to come in to confirm.
Post by knebby on Mon 9 Nov 2015 - 21:47
Mine had an awful misfire and engine light coming on and off. New coil pack sorted it. Incidentally the garage had a Polo in with the same thing the same day.
Post by johntymac on Tue 10 Nov 2015 - 15:25
mine was misfiring, coil...spark plugs ok..got it re-maped, going like the wind. sorry,
johntymac
Post by LukeC on Fri 13 Nov 2015 - 22:55
Right some information while I remember
Air box held on by 4 T25 screws you'll need a 100mm thin handle screwdriver ; came out easy enough
Pipe to airbox needs removing there's to buttons as you will one on top,one on the bottom push these in and giggle free until they're past the edge of the box (edge of box holding it on) then giggle free
Coil pack is held on by 4 T30 bolts the left two are near impossible so you will need a bendi attachment from your ratchet the bottom right also has a metal coating under the plastic which causes it to rust to the engine block and bolt so be careful as this one is prone to sheering
Post by LukeC on Fri 13 Nov 2015 - 23:33
Oh and theres a clip holding on the power supply you'll need to push this upwards and then pull the supply out
Post by LukeC on Sat 14 Nov 2015 - 16:22
Refit in reverse order I replaced the bolts with Allen key bolts with socket heads on the coil pack to make it easier in future (copper greased of course)
Spark plugs were a simple enough job did them with a 8/14mm 250mm spark plug socket so they were an easy job 25nm torque
Post by LukeC on Sat 14 Nov 2015 - 23:49
A quick image showing the rust
https://imgur.com/MMUH0yN
The new coil pack has a plastic coating all around where as this one had metal touching the bolt there was also no copper grease on them which I'd recommend applying before refitting
