Fitting a head lining
Fitting a head lining Empty Fitting a head lining
Post by Araf Mon 16 Mar 2015 - 21:41
1/ Open the roof, but leave the rear cover up.
2/ With paper, mark out just over half of the inner panel
Fitting a head lining P1010610
3/ Transfer the paper pattern onto 3mm closed cell foam (I got it from ebay).
Do not use a self adhesive foam, as the adhesive doesn't work well in summer.  Instead, I stuck it to the roof using Dunelm Mills aerosol Spray Adhesive.
4/ Stick the foam into the recess
Fitting a head lining P1010713
5/ Now make a paper template to follow the roof contours
Fitting a head lining P1010712
6/ Cut out another piece of foam, and trial fit it to the recess.
7/ coat one side in the adhesive glue, and stick on fabric of your choice.  I went for Nu-Suede from Dunelm in black.
8/ Leaving a border of about 10mm, cut the fabric around the foam.
9/ Spray the edge of the foam/fabric with glue, and quickly fold the edge of the fabric over and stick it to the foam.
10/ Now spray the remainder of the foam back with glue, and slightly onto the fabric that you have just folded over.
11/ Stick the headlining with foam to the roof.
12/ Stand back, and admire your work. Smile
Fitting a head lining Roof_f10
I'll update links to the glue, fabric, and foam, when I can next week. Smile
Fitting a head lining Empty Re: Fitting a head lining
Post by Barbs Mon 16 Mar 2015 - 21:51
Looked professional job
Post by Araf Mon 16 Mar 2015 - 22:18
Not as good as the one I did on my BMW. Cool
** Cool was for the job I did, not the car. Wink
Post by Anthony1664 Tue 17 Mar 2015 - 22:49
Now I like that, there was complaints about dripping condensation in our wind in the cold of winter reckon this might well cure that issue
Anthony1664
Anthony1664
Post by Araf Tue 17 Mar 2015 - 23:16
Yes it would. I've never had that problem, and just an insulated headlining stopped the condensation in my old Land Rover. Smile
Post by Anthony1664 Wed 18 Mar 2015 - 8:40
I can offer you an old Landrover to rebuild if you want a project, there is a half finished S2a sitting on my drive looking for a new owner to show it some love Very Happy Very Happy
Anthony1664
Anthony1664
Post by Araf Wed 18 Mar 2015 - 11:59
I'll pass on that. I had a SIII, then an SIII lightweight. They are from a bygone age, and deserve to stay there. Smile
Post by Anthony1664 Thu 19 Mar 2015 - 21:15
It was bought one nite when both beer and EBay were involved, I had previously owned a SIII for years and following a snowy winter seemed like a good idea to get a tax exempt truck..... The work began then a motorbike vs car incident broke my shoulder and I lost intrest in the big jibs like removing the engine, changing the bulkhead and swaping the rear axel so there she lies with nothing done for over 3 years!!!
Anthony1664
Anthony1664
