Fitting a head lining
1/ Open the roof, but leave the rear cover up.
2/ With paper, mark out just over half of the inner panel
3/ Transfer the paper pattern onto 3mm closed cell foam (I got it from ebay).
Do not use a self adhesive foam, as the adhesive doesn't work well in summer. Instead, I stuck it to the roof using Dunelm Mills aerosol Spray Adhesive.
4/ Stick the foam into the recess
5/ Now make a paper template to follow the roof contours
6/ Cut out another piece of foam, and trial fit it to the recess.
7/ coat one side in the adhesive glue, and stick on fabric of your choice. I went for Nu-Suede from Dunelm in black.
8/ Leaving a border of about 10mm, cut the fabric around the foam.
9/ Spray the edge of the foam/fabric with glue, and quickly fold the edge of the fabric over and stick it to the foam.
10/ Now spray the remainder of the foam back with glue, and slightly onto the fabric that you have just folded over.
11/ Stick the headlining with foam to the roof.
12/ Stand back, and admire your work.
I'll update links to the glue, fabric, and foam, when I can next week.
Re: Fitting a head lining
Looked professional job
Not as good as the one I did on my BMW.
** was for the job I did, not the car.
Now I like that, there was complaints about dripping condensation in our wind in the cold of winter reckon this might well cure that issue
Anthony1664- Took the roof down
Yes it would. I've never had that problem, and just an insulated headlining stopped the condensation in my old Land Rover.
I can offer you an old Landrover to rebuild if you want a project, there is a half finished S2a sitting on my drive looking for a new owner to show it some love
I'll pass on that. I had a SIII, then an SIII lightweight. They are from a bygone age, and deserve to stay there.
It was bought one nite when both beer and EBay were involved, I had previously owned a SIII for years and following a snowy winter seemed like a good idea to get a tax exempt truck..... The work began then a motorbike vs car incident broke my shoulder and I lost intrest in the big jibs like removing the engine, changing the bulkhead and swaping the rear axel so there she lies with nothing done for over 3 years!!!
» Roof rattle behind drivers head
» Fitting 15's
» 2010 MODEL WITH KNACKERED RADIO HEAD UNIT
» Fitting a dash cam
» Fitting a centre armrest
» Fitting 15's
