Spare Wheel
Spare Wheel
Just a thought in case anyone didn't know. It is possible to fit a full size spare wheel in the car. Mine came with a space saver think the other option was the gloop but after having to drive on the A1 with the spare wheel speed restrictions. Araf advised me with a little modification the car can fit in a full size spare wheel. If you trim the little plastic lip near the bottom of the panel it will fit in, The carpet sits a little raised but not that noticeable.
Re: Spare Wheel
I bought a Clio 14 inch steel wheels and some steel wheel bolts off EBay, the wheel fits the hole nicely, the car on the other hand it only fits the rear so if we pick up a front puncture it will be a double wheel roadside swap
Anthony1664- Took the roof down
Re: Spare Wheel
it is just a little trim on the plastic bit that allows a 17 inch wheel to fit in. Carpet raised a bit but not that you would noticeAnthony1664 wrote:I bought a Clio 14 inch steel wheels and some steel wheel bolts off EBay, the wheel fits the hole nicely, the car on the other hand it only fits the rear so if we pick up a front puncture it will be a double wheel roadside swap
Re: Spare Wheel
I was hunting for a 17 inch wheel but failed to find one cheep hence the Clio 14 incher
Re: Spare Wheel
Think I was lucky Araf sold me one. Had a puncture on the way back from Scotland a couple of years ago. Fitted the space saver, restriction of 50 mph was scary.
Re: Spare Wheel
A 15" wheel goes over the front brakes Anthony. If you get a 15" alloy, you don't need to carry spare bolts.
Re: Spare Wheel
Got the space saver, but luckly never had to use it (yet, touch wood).
Anything is better than goo and compressor, as thats never guarenteed 100% effective, whereas a spare gets you away and running again.
Re: Spare Wheel
That is so true. Driving on the space saver was so scary. I don't drive fast but think people see it's a roadster and expect you to drive fast. I am not comfortable with a car up my exhaust so the full size spare is a good alternative for me. Also having that I can shop around for the best price if faced with needing a replacement. Living in a City you don't always think about how easy it is to replace a tyre.colin565 wrote:Got the space saver, but luckly never had to use it (yet, touch wood).
Re: Spare Wheel
A 15" wheel goes over the front brakes Anthony. If you get a 15" alloy, you don't need to carry spare bolts. Smile
Ahr but the one I have is 14inch hence not fitting the brakes and the need for the bolts
Re: Spare Wheel
I could indeed do that but then it ain't too much of a hardship to do a double swap it a front puncture gets picked up
Re: Spare Wheel
Anthony1664 wrote:I could indeed do that but then it ain't too much of a hardship to do a double swap it a front puncture gets picked up
I quite agree. The chances of a puncture are pretty slim anyway, so it's not as if you're going to be doing it every week.
Re: Spare Wheel
Hmm, a couple of years back in the Wind I went over an unmarked and unilluminated pedestrian crossing in a pitch black evening with a storm raging. The result was offside punctures front and rear. In those circumstances it doesn't matter whet size spare you've got or whether it's a bottle of goo, you ain't gonna get home without help. RAC recovery came to the rescue.
