more mods needed
more mods needed Empty more mods needed
Post by Dr@gon on Tue 14 Jul 2015 - 18:15
does anyone know were I could get a front strut brace and stainless exhaust?
more mods needed Empty Re: more mods needed
Post by CheekyWind on Tue 14 Jul 2015 - 21:49
Araf is your best bet.
Cheers. Gazza.
CheekyWind
CheekyWind
Post by Barbs on Tue 14 Jul 2015 - 22:04
Or @moving shadow he has changed a lot
Post by Araf on Wed 15 Jul 2015 - 14:57
This one should fit - as should any from the Twingo RS, but you may want to check with K-tec first.
http://www.k-tecracing.com/show_product.asp?id=4851&appid=18
Frankly, you don't want to make the front stiffer like that, or it will just make the roof rattle more. If you want to sharpen the car up, look at an uprated anti-roll bar instead - unless it's the bling factor that you're after. Smile
Post by Dr@gon on Wed 15 Jul 2015 - 15:54
ok ill lose that then will twingo exhaust fit?
Post by Araf on Wed 15 Jul 2015 - 17:21
Should be a straight swap. Smile
