Spare Wheel
Spare Wheel Empty Spare Wheel
Post by Barbs Mon 30 Mar 2015 - 12:51
Just a thought in case anyone didn't know. It is possible to fit a full size spare wheel in the car. Mine came with a space saver think the other option was the gloop but after having to drive on the A1 with the spare wheel speed restrictions. Araf advised me with a little modification the car can fit in a full size spare wheel. If you trim the little plastic lip near the bottom of the panel it will fit in, The carpet sits a little raised but not that noticeable.
Spare Wheel Empty Re: Spare Wheel
Post by Anthony1664 Mon 14 Sep 2015 - 22:25
I bought a Clio 14 inch steel wheels and some steel wheel bolts off EBay, the wheel fits the hole nicely, the car on the other hand it only fits the rear so if we pick up a front puncture it will be a double wheel roadside swap
Anthony1664
Anthony1664
Post by Barbs Mon 14 Sep 2015 - 22:27
Anthony1664 wrote:I bought a Clio 14 inch steel wheels and some steel wheel bolts off EBay, the wheel fits the hole nicely, the car on the other hand it only fits the rear so if we pick up a front puncture it will be a double wheel roadside swap
it is just a little trim on the plastic bit that allows a 17 inch wheel to fit in. Carpet raised a bit but not that you would notice
Post by Anthony1664 Mon 14 Sep 2015 - 22:38
I was hunting for a 17 inch wheel but failed to find one cheep hence the Clio 14 incher
Anthony1664
Anthony1664
Post by Barbs Mon 14 Sep 2015 - 22:45
Think I was lucky Araf sold me one. Had a puncture on the way back from Scotland a couple of years ago. Fitted the space saver, restriction of 50 mph was scary.
Post by Araf Mon 14 Sep 2015 - 23:09
A 15" wheel goes over the front brakes Anthony.  If you get a 15" alloy, you don't need to carry spare bolts. Smile
Post by colin565 Tue 15 Sep 2015 - 22:18
Got the space saver, but luckly never had to use it (yet, touch wood).
Anything is better than goo and compressor, as thats never guarenteed 100% effective, whereas a spare gets you away and running again.
Post by Barbs Tue 15 Sep 2015 - 22:35
colin565 wrote:Got the space saver, but luckly never had to use it (yet, touch wood).
That is so true. Driving on the space saver was so scary. I don't drive fast but think people see it's a roadster and expect you to drive fast. I am not comfortable with a car up my exhaust so the full size spare is a good alternative for me. Also having that I can shop around for the best price if faced with needing a replacement. Living in a City you don't always think about how easy it is to replace a tyre.
Post by Anthony1664 Fri 18 Sep 2015 - 22:59
Ahr but the one I have is 14inch hence not fitting the brakes and the need for the bolts
Anthony1664
Anthony1664
Post by Araf Sat 19 Sep 2015 - 0:31
So get a 15, and flog the 14?
Post by Anthony1664 Sun 20 Sep 2015 - 17:08
I could indeed do that but then it ain't too much of a hardship to do a double swap it a front puncture gets picked up
Anthony1664
Anthony1664
Post by Araf Sun 20 Sep 2015 - 21:50
Anthony1664 wrote:I could indeed do that but then it ain't too much of a hardship to do a double swap it a front puncture gets picked up
I quite agree.  The chances of a puncture are pretty slim anyway, so it's not as if you're going to be doing it every week. Smile
Post by knebby Sun 20 Sep 2015 - 23:14
Hmm, a couple of years back in the Wind I went over an unmarked and unilluminated pedestrian crossing in a pitch black evening with a storm raging. The result was offside punctures front and rear. In those circumstances it doesn't matter whet size spare you've got or whether it's a bottle of goo, you ain't gonna get home without help. RAC recovery came to the rescue.
