Maximum RPM
Maximum RPM Empty Maximum RPM
Post by monkey121 Thu 18 Jun 2015 - 20:13
Does anyone know whats the Max RPM you can take the wind to? And when does the change gear light displayed?
monkey121
monkey121
Maximum RPM Empty Re: Maximum RPM
Post by Barbs Thu 18 Jun 2015 - 20:26
monkey121 wrote:Does anyone know whats the Max RPM you can take the wind to? And when does the change
light displayed?
I've only ever seen the light once scared me lol
Post by Araf Thu 18 Jun 2015 - 20:35
You can't over-rev the engine on the throttle as it has a limiter. It's generally a couple of hundred revs above the red line, painted on the rev counter.
As for the change light, the only time I've seen it, is on track, and then I was concentrating on the track and changing gear, I'm afraid.
Why the question Monkey?
Post by monkey121 Thu 18 Jun 2015 - 20:38
Araf wrote:Why the question Monkey?
Well I was pulling away today in 1st gear and was only around 5500 revs and it felt like the engine was hitting the rev limit (lose of power) and i thought i saw the light flash on. I wouldnt have thought 5500 revs would have been the limit
monkey121
monkey121
Post by Araf Thu 18 Jun 2015 - 22:24
No, it's not. I've just been out to check, and the red line is at 6500 revs. I'm not sure the cars are sophisticated enough, but it could be that if the engine hasn't been on long, it could have a lower rev limit until the engine warms properly.
You shouldn't need 5500 revs to pull away - you speed demon. Wink
Post by monkey121 Fri 19 Jun 2015 - 10:16
Araf you are right it appears the engine limits the revs to 5500 until it warms up.
monkey121
monkey121
Post by Araf Fri 19 Jun 2015 - 17:15
In that case, very naughty you. Laughing
Post by D Fri 19 Jun 2015 - 17:51
if you want to use even more revs perhaps the Superchips Bluefin engine tuning I've been having a look at is just the thing to use
D
Cruising down the highway
Post by Araf Fri 19 Jun 2015 - 20:28
I wouldn't bother Darren, unless you have a turbo - and if that's the case, then your injectors will need replacing, as they will max out.
I tried a custom remap (twice), which are better than Bluefins, and the map reverted to standard. From what I understand, the Wind has a safety feature underwritten, which stops too much torque being produced, and prematurely wearing the clutch.
Post by D Fri 19 Jun 2015 - 20:34
Yes mine is the turbo - though good to know about the mapping as I had thought not worth it really. Decided a decent service and fresh sparks and filters the way to go
D
