New Number Plates
New Number Plates
Anyone got any recommendations for new Number Plates. Mine had a thin plastic skin on and its come off and now the numbers and lettering are starting to break down. Sam (the Twingo) had some nice plates that were raised and stuck with double sided tape that looked good but don't want to end up on the wrong side of the law.
Re: New Number Plates
Here's some pressed plates, if that's what you want
http://www.ebay.co.uk/itm/PRESSED-ALUMINIUM-NUMBER-PLATES-YELLOW-WHITE-/141292825494?_trksid=p2141725.m3641.l6368
Thanks Araf I will sort them tonight.
New plates ordered
thanks Araf as always...
Barbs wrote:New plates ordered
Wait until they arrive before saying thanks - and anyway, it's only a link I gave.
New Plates arrived went for the raised gel type now I just have to stick them on.
If you're sticking them on, then get some of this
http://www.ebay.co.uk/itm/Black-Extra-Strong-Permanent-Double-Sided-Self-Adhesive-Foam-Car-Trim-Body-Tape-/261823609356?var=&hash=item3cf5e73a0c
12mm or 19mm will be fine, and you need to cut four 12mm strips or three 19mm strips to go vertically on the number plate. Stick them to the number plate, then stick the plate to the car, apply pressure and rub to get rid of bubbles, and that should be it.
If your old plate was screwed on, and you're going to do the same with this, then remove the old plate, and use it as a template for drilling the holes in the new one.
Good luck.
Good luck.
Project for the weekend. Scary.... I want to use the stick strips. Graham wants to use his new drilllllll could be Divorce
Update..
I want to stick number plate on the car, Graham wants to drill holes in the Plates, fear of it not sticking with the tape they supplied. So the plan now is to take the plates into Work and ask the nice Guys down the road to fit them.
Before I make the final decision does anyone have stuck on Plates.
Yes, the current ones are screwed (by the garage at thelast MOT), but the old ones were previously stuck on. The truck has stuck on plates too.
I have lovely new Plates screwed on. The nice men over the road put them on for me this morning. Happy bunny.
What's the legal stance on pressed plates then?
LukeC wrote:What's the legal stance on pressed plates then?
If they're the correct font, the correct spacing, BSI stamped, and carry the maker's identity, they're fine.
If they're German plate font, and incorrectly spaced, you're asked to be tugged.
DVLA Show a guide and that is what i followed. The Invoice also quotes legal plates. Hope that is all i need.
Do the plates not need to be reflective though which the steel isn't? In most cases anyway; unless they stick some kind of vinyl on it these days as if its not reflective ampr cameras can't read the reg
» Black private plates Cowbridge
» and in at number 19 is..........
» And at number 6 we have.....
» Wind of different colours
» Registration number W1NDY
