Boot closing opening problem
Boot closing opening problem Empty Boot closing opening problem
Post by Renkev on Wed 2 Oct 2019 - 18:55
Have an issue with above.
Go to car and open doors with remote all good. Then go to open boot but won't open.
I then press key a few times and it opens and then close boot and it pops back open.
Do this a few times and it either pops open straightaway or after say 10 secs.
Eventually it will close but it unsure of what the issue is.
Renkev
Boot closing opening problem Empty Re: Boot closing opening problem
Post by Mistydogblue on Wed 2 Oct 2019 - 23:02
Hi renaults in general have an issue with the boot lock switch (the rubber switch you press on the boot to open it). It comes off quite easily and you could try to clean up the contacts but a new one is only about £15 and readily available on ebay or amazon etc. If you go into ebay and search for renault wind boot release switch you will see what they look like. The switch is the same for the wind, clio, modus and other models and is a straightforward swop.
Post by Renkev on Thu 3 Oct 2019 - 7:02
How do u clean the contacts?
Renkev
Post by Mistydogblue on Fri 4 Oct 2019 - 8:50
A bit of sandpaper. The switches ofte
A bit of sandpaper will clean them. Water often gets into the switch and the contacts become corroded and pitted.
Post by Renkev on Fri 4 Oct 2019 - 10:09
I'm having the boot switch replaced.
Renkev
